StarTech.com Standalone 1:3 SATA 2.5 / 3.5" Hard Drive Duplicator and Eraser w/ Daisy Chaining
Quicklinx: 92PZWS00 Mfr#: SATDUP13
Clone or erase 2.5in/3.5in SATA hard drives, without a host computer connection. The SATDUP13 standalone HDD duplicator/eraser lets you copy up to three, or erase up to four SATA HDDs or SSDs simultaneously, without having to connect to a host computer. The duplicator/eraser works with any 3.5" or 2.5" SATA Hard Drive or Solid State Drive, and features an integrated LCD that makes it easy to monitor cloning/erasing performance.
The versatile 1-to-3 duplicator features three operating modes for duplication, including Data Only, All Partitions, and Sector by Sector cloning, and delivers high-performance duplication speeds to help save you time (tested for speeds up to 14GB per minute).
The SATDUP13 also offers several erase modes, including Quick Erase, Secure Erase, and Single-Pass/Multi-Pass Hard Drive Overwriting (DoD), which passes over the hard drive 3 times to ensure that the data has been completely wiped.
For increased scalability, the HDD duplicator/eraser features a unique daisy-chain port that gives you the option to combine multiple SATDUP13 units together, allowing up to four additional drives to be erased or copied with each added unit to help save you time.
StarTech.com Standalone 1:3 SATA 2.5 / 3.5" Hard Drive Duplicator & Eraser - hard drive duplicator
Hard drive duplicator
0 (installed) / 4 (max)
Supported Drives
SATA-600
North America, United Kingdom, Europe
Built-in Devices
Status LCD
Storage Controller
SATA (SATA 6Gb/s)
AC 120/230 V - 50/60 Hz
26.3 cm x 12 cm x 4 cm
0.95 kg
Enclosure Colour
Chassis
Built-in Devices
Status LCD
0
Supported Devices / Modules Qty
4
Supported Drives
SATA-600
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Max Storage Devices Qty
4
Expansion Bays
4 (total) / 4 (free) x external - 2.5" / 3.5" shared
4 x SATA 6Gb/s - 22 pin Serial ATA
4 x Serial ATA cable
FCC, RoHS
External power adapter
26.3 cm
12 cm
4 cm
0.95 kg
5 °C
45 °C
20 - 80%
