This Cat 6 RJ45 Modular Plug can be used with Cat 6 bulk cables, allowing you to easily terminate your Cat 6 cable to the exact length equired.
- StarTech.com Cat 6 RJ45 Modular Plug for Solid Wire - 50 Pack (CRJ45C6SOL50) - network connector - clear
- Network connector - CAT 6
- Packaged Quantity
- 50 (specifications are for single item)
- Connector
- RJ-45 - male
- Clear
- Limited lifetime warranty
- Designed For
- P/N: WIRC6CMPBLU
- Packaged Quantity
- Network Cable Type
- Clear
- Connector
- RJ-45 - male
- RoHS
- Designed For
- P/N: WIRC6CMPBLU
StarTech.com 1000 ft Bulk Roll of Gray CMR Cat 6 Solid UTP Riser Cable | In Stock | £312.47 |
StarTech.com 1000ft Cat6 Ethernet Cable CMR | In Stock | £312.47 |
