Product
StarTech.com SlimPort / MyDP to VGA Video Converter – Micro USB to VGA Adapter for HP ChromeBook 11
Quicklinx: 9QB3WS00 Mfr#: SLMPT2VGA
Select:
£16.36 ex VAT
£19.63 inc VAT
Connect your SlimPort enabled device to a VGA monitor or projector, ideal for SlimPort-enabled Chromebook computers. The SLMPT2VGA Micro USB (SlimPort) to VGA adapter lets you to connect a SlimPort / MyDP-enabled laptops, such as your HP Chromebook 11, and LG Optimus G Pro & LG G2 smartphones, to any VGA-enabled television, monitor or projector. The adapter lets you increase productivity by extending your desktop for more workspace, or share your screen with a larger display for group viewing.
The SlimPort to VGA adapter supports video resolutions up to 1920x1200 at 60 frames per second, to deliver high resolution video content to your VGA display without sacrificing video quality on games or videos. You can also use the 3.5 mm audio jack on your source device to provide stereo audio to your speakers. Simply connect a 3.5 mm audio cable, from your source device to your display device or speaker system.
The adapter offers a Micro USB port on the side, for the added benefit of simultaneously charging your mobile device, so it is always ready to use. Plus, the SLMPT2VGA is compact and lightweight, to easily travel as a smartphone or Chromebook accessory for maximum portability.
The SlimPort adapter is intended for displaying user generated content such as presentations, documents, and work sheets onto a VGA projector or monitor. HDCP encrypted content will not be displayed and certain devices output HDCP for all content, by default these devices will not function with this adapter.
StarTech.com SlimPort MyDP to VGA Converter - 1080p - external video adapter - black
External video adapter
Bus Type
SlimPort (5 pin Micro-USB)
Max Resolution
1920 x 1200
USB , VGA , USB
2.6 cm x 4 cm x 1 cm
Enclosure Colour
2 years warranty
Bus Type
Max Resolution
1920 x 1200
USB , VGA , USB
FCC, RoHS
2.6 cm
4 cm
1 cm
18 g
Enclosure Colour
60 °C
9QB3 StarTech.com 3ft Micro USB Cable - A to Micro B In Stock £3.79
9QB3 StarTech.com 1ft Micro USB Cable - A to Micro B In Stock £3.68
Price Range Ex VAT: 0 - 50
