This cost-saving Slimline SATA to SATA adapter lets you connect a Slimline SATA optical drive to a standard SATA motherboard connection. The adapter features a Slimline SATA connector on one side and a standard SATA data connector on the other; power is drawn through a power supply floppy drive (SP4) connector, combining both data and power into the optical drive Slimline SATA connection. The adapter features a PCB-mounted design that can be securely fastened to the optical drive, eliminating loose connections.
- StarTech.com Female Slimline SATA to SATA Adapter with SP4 Power - SATA adapter
- SATA adapter
- Connectors
- 13 pin Slimline Serial ATA - female
- Connectors (Second End)
- 7 pin Serial ATA - male , 4 PIN internal power - male
- Black
- Limited lifetime warranty
- Storage Cable Type
- SATA adapter
- Black
- Connectors
- RoHS
