StarTech.com Slimline SATA to SATA Adapter with Power - F/M
Quicklinx: 68KYWS00 Mfr#: SLSATAADAP
Use new Slimline drives with older motherboards.
The SLSATAADAP Slimline SATA to SATA adapter is a cost-saving solution that allows you to connect a Slimline SATA optical drive to a standard SATA motherboard connection. The adapter features a Slimline SATA connector on one side and a standard SATA data connector on the other; power is drawn through a power supply SATA power connector, combining both data and power into the optical drive Slimline SATA connection.
StarTech.com Slimline SATA to SATA Adapter with Power - F/M - SATA adapter
SATA adapter
Interface Speed
Serial ATA 150/300/600
Connector
13 pin Slimline Serial ATA - female
Connector (Second End)
22 pin Serial ATA - male
Storage Cable Type
SATA adapter
Interface Speed
Connector
RoHS
68KY StarTech.com 6in Slimline SATA to SATA Adapter with Power - F/M In Stock £9.28
