Connect a VGA display through this slim USB 3.0 Adapter for a multi-monitor solution ideal for your Ultrabook or Laptop. The USB32VGAES Slim USB 3.0 to VGA Adapter turns a USB 3.0 port into a VGA output port with 1920x1200/1080p video support. The adapter minimizes clutter with a slim design that seamlessly blends with your video cable - an ideal space-saving solution for multi-monitor applications on Ultrabook, laptop, or desktop computers.
Functioning as an external graphics card, this USB to VGA adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
To save space while traveling, this ultra-portable USB to VGA adapter features a lightweight, small footprint design that fits easily in a laptop carrying bag.
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your VGA display/projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
- StarTech.com USB 3.0 to VGA Adapter - Slim Design - 1920x1200 - adapter - VGA / USB - TAA Compliant - 19 cm
- Cable
- Adapter - VGA / USB
- TAA Compliant
- Max Output Resolution
- 1920 x 1200
- Length
- 19 cm
- Black
- Connector
- USB Type A - male (input)
- Connector (Second End)
- HD-15 (VGA) - female (output)
- USB 2.0/ USB 3.0
- USB powered, slim
- 2-year warranty
- Designed For
- P/N: MXT101MM
- Cable Type
- Adapter
- Interface Supported
- VGA / USB
- Jacket Material
- Plastic
- USB 2.0/ USB 3.0
- Length
- 19 cm
- USB powered, slim
- Black
Adapters & Converters
- 1920 x 1200
- OS Required
- Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
- Connector
- 9 pin USB Type A - male (input)
- 15 pin HD D-Sub (HD-15) - female (output)
- WHQL, FCC, RoHS, WEEE, REACH, RCM
- TAA Compliant
- 2.5 cm
- 1.2 cm
- 25 g
- Shipping Width
- 17.1 cm
- Shipping Depth
- 15.1 cm
- Shipping Height
- 3.2 cm
- Shipping Weight
- 148 g
- Limited warranty - 2 years
- Designed For
- P/N: MXT101MM
