Product
StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p
Quicklinx: 98FXWS00 Mfr#: USB32VGAES
More than 50 in stock
£39.07 ex VAT
£46.88 inc VAT
Standard delivery Delivered within 3-5 working days
Connect a VGA display through this slim USB 3.0 Adapter for a multi-monitor solution ideal for your Ultrabook or Laptop. The USB32VGAES Slim USB 3.0 to VGA Adapter turns a USB 3.0 port into a VGA output port with 1920x1200/1080p video support. The adapter minimizes clutter with a slim design that seamlessly blends with your video cable - an ideal space-saving solution for multi-monitor applications on Ultrabook, laptop, or desktop computers.
Functioning as an external graphics card, this USB to VGA adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
To save space while traveling, this ultra-portable USB to VGA adapter features a lightweight, small footprint design that fits easily in a laptop carrying bag.
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your VGA display/projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter - external video adapter - T5-302 - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Graphics Engine
MCT Trigger 5 T5-302
Max Resolution
1920 x 1200
VGA
2.5 cm x 6.2 cm x 1.2 cm
Enclosure Colour
2 years warranty
Bus Type
SuperSpeed USB 3.0
Graphics Engine
Max Resolution
1920 x 1200
VGA
USB powered
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
Min Processor Type
Intel Core i3 2.8 GHz
Min RAM Size
2 GB
Additional Requirements
USB port
1 x USB cable - 6.2 cm
Software Included
Drivers & Utilities
WHQL, FCC, RoHS
2.5 cm
6.2 cm
1.2 cm
Enclosure Colour
50 °C
0 - 85% (non-condensing)
98FX StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £3.93
98FX StarTech.com 6 ft Monitor VGA Cable - HD15 M/M In Stock £2.22
98FX StarTech.com 10 ft VGA Monitor Cable - HD15 MM In Stock £4.46
98FX StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M In Stock £9.79
Price Range Ex VAT: 0 - 50
