StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p
Quicklinx: 97QKWS00 Mfr#: USB32HDES
More than 50 in stock
£44.38 ex VAT
£53.25 inc VAT
Connect an HDMI display through this slim USB 3.0 Adapter for a multi-monitor solution ideal for your Ultrabook or Laptop. The USB32HDES Slim USB 3.0 to HDMI Adapter turns a USB 3.0 port into an HDMI output with 1920x1200/1080p video support. The adapter minimizes clutter with a slim design that seamlessly blends with your video cable - an ideal space-saving solution for multi-monitor applications on Ultrabook, laptop, or desktop computers.
Functioning as an external graphics card, this USB to HDMI adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
To save space while traveling, this ultra-portable USB to HDMI adapter features a lightweight, small footprint design that fits easily in a laptop carrying bag.
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your HDMI display/projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
StarTech.com USB 3.0 to HDMI Display Adapter Converter 1080p (1900x1200) Dual / Multi-Monitor Video Cable w/ External Graphics Card - Supports Windows (USB32HDES) - external video adapter - T5-302 - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Graphics Engine
MCT Trigger 5 T5-302
Max Resolution
1920 x 1200
HDMI
2.5 cm x 6.2 cm x 1.2 cm
Enclosure Colour
Bus Type
SuperSpeed USB 3.0
Graphics Engine
Max Resolution
1920 x 1200
HDMI
USB powered
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
Min Processor Type
Intel Core i3 2.8 GHz
Min RAM Size
2 GB
1 x SuperSpeed USB cable - 6.2 cm
Software Included
Drivers & Utilities
WHQL, FCC, RoHS
2.5 cm
6.2 cm
1.2 cm
Enclosure Colour
50 °C
0 - 85% (non-condensing)
97QK StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter In Stock £71.20
97QK StarTech.com 5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £13.48
97QK StarTech.com USB 3 to HDMI w/ USB Hub In Stock £48.28
97QK StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £44.38
97QK StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC In Stock £51.94
97QK StarTech.com USB 3.0 to 4K HDMI External Multi Monitor Video Graphics Adapter In Stock £68.54
97QK StarTech.com USB 3.0 to Dual HDMI Adapter In Stock £55.84
Price Range Ex VAT: 0 - 50
