Connect an HDMI display through this slim USB 3.0 Adapter for a multi-monitor solution ideal for your Ultrabook or Laptop. The USB32HDES Slim USB 3.0 to HDMI Adapter turns a USB 3.0 port into an HDMI output with 1920x1200/1080p video support. The adapter minimizes clutter with a slim design that seamlessly blends with your video cable - an ideal space-saving solution for multi-monitor applications on Ultrabook, laptop, or desktop computers.
Functioning as an external graphics card, this USB to HDMI adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
To save space while traveling, this ultra-portable USB to HDMI adapter features a lightweight, small footprint design that fits easily in a laptop carrying bag.
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your HDMI display/projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
- StarTech.com USB 3.0 to HDMI Adapter, 1080p (1920x1200), Slim/Compact USB to HDMI Display Adapter Converter for Monitor, USB Type-A External Video & Graphics Card, Black, Windows Only - USB to HDMI Adapter (USB32HDES) - adapter cable - HDMI / USB - TAA Compliant - 19 cm
- Cable
- Adapter cable - HDMI / USB
- TAA Compliant
- Max Output Resolution
- 1920 x 1200
- Length
- 19 cm
- Black
- Connector
- USB Type A - male (input)
- Connector (Second End)
- HDMI - female (output)
- USB 2.0/ USB 3.0
- 1080p support
- 2-year warranty
- Designed For
- P/N: HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
- Cable Type
- Adapter cable 1080p support
- Interface Supported
- HDMI / USB
- Jacket Material
- Plastic
- USB 2.0/ USB 3.0
- Length
- 19 cm
- Slim, multi-channel audio
- Black
Adapters & Converters
- 1920 x 1200
- OS Required
- Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
- Connector
- 9 pin USB Type A - male (input)
- 19 pin HDMI Type A - female (output)
- WHQL, FCC, RoHS, WEEE, REACH, RCM
- TAA Compliant
- 2.5 cm
- 1.2 cm
- 25 g
- Shipping Width
- 14.8 cm
- Shipping Depth
- 17.5 cm
- Shipping Height
- 3.2 cm
- Shipping Weight
- 144 g
- Limited warranty - 2 years
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.28 |
StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter | In Stock | £77.49 |
StarTech.com 5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M | In Stock | £19.45 |
StarTech.com USB 3 to HDMI w/ USB Hub | In Stock | £67.65 |
StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £36.51 |
StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC | In Stock | £53.32 |
StarTech.com USB 3.0 to Dual HDMI Adapter | In Stock | £46.27 |
StarTech.com USB 3.0 to DisplayPort Adapter | In Stock | £60.35 |
StarTech.com USB to Dual DisplayPort 4K 60Hz | In Stock | £85.46 |
StarTech.com 6ft Premium Certified HDMI 2.0 | In Stock | £16.15 |
