StarTech.com Slim USB 3.0 to DP Video Card
Quicklinx: BM02WS00 Mfr#: USB32DPES
Connect your Ultrabook or laptop to a DP monitor using an external USB video card. This slim USB 3.0 to DisplayPort adapter turns a USB 3.0 port into a DP output. The adapter minimizes clutter with a slim, space-saving design that seamlessly blends with your video cable, making it perfect for multi-monitor applications on Ultrabook, laptop, or desktop computers.
The USB to DisplayPort adapter supports resolutions up to 2048 x 1152 and is also compatible with lower-resolution displays supporting 1920x1200 or 1080p.
With multiple monitors connected to your laptop or desktop computer, you can boost your productivity because you have more screen space to work from.
Functioning as an external graphics card, this USB to DP adapter offers a convenient way to increase your productivity by adding multi-monitor capability to your USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
This ultra-slim USB to DisplayPort adapter features a lightweight design with a small footprint that blends seamlessly into your monitor cable for a tidy professional workspace.
Its compact design also ensures the adapter will fit easily into your laptop carrying bag, making it the perfect travel companion to work with your Bring Your Own Device (BYOD) hot-desk.
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your DisplayPort monitor. The adapter makes it easy to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace.
This adapter will not output digitally encrypted content.
StarTech.com Slim USB 3.0 to DisplayPort Adapter - External USB Video Card - external video adapter - T5-302 - 16 MB - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Graphics Engine
MCT Trigger 5 T5-302
16 MB DDR2
Max Resolution
2560 x 1600
Interfaces Details
DisplayPort
1.4 cm x 8.8 cm x 19.5 cm
Enclosure Colour
P/N: MDP2DPMM10, MDP2DPMM3, MDP2DPMM6, MDP2DVIMM6BS
Bus Type
SuperSpeed USB 3.0
Graphics Engine
Max Resolution
2560 x 1600
Interfaces Details
DisplayPort
USB powered
Size
16 MB
DDR2 SDRAM
Microsoft Windows XP / Vista / 7 / 8 / 8.1 (32/64 bits)
1 x SuperSpeed USB cable - 6.2 cm
WHQL, FCC, RoHS, WEEE, RCM
1.4 cm
8.8 cm
19.5 cm
43 g
Enclosure Colour
Limited warranty - 2 years , Technical support - lifetime
50 °C
0 - 85% (non-condensing)
BM02 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.12
