StarTech.com Sit-to-stand Workstation - Slim
Quicklinx: C9J7WS00 Mfr#: BNDSTSSLIM
Turn your desk into a sit-stand workspace with a slim monitor mount that features full-motion articulation. This sit-to-stand workstation offers an easy way to enhance your productivity and comfort, by giving you a work space with a built-in articulating monitor mount that's easy to adjust according to your desired working position.
With one touch, you can switch your position from sitting to standing or vice versa, to keep a balanced level of movement throughout the day. The workstation features an advanced pneumatic spring that makes it easy to raise or lower the platform. Whether you want to sit or stand while you're working, it's easy to adjust the standing desk to match your exact height requirements, instead of selecting from pre-determined heights.
You can also adjust the tension of the spring according to the weight of monitors, laptops and other components on the platform, to make raising or lowering the workstation even easier.
For viewing longer pages or blocks of code without having to scroll down your screen, the included monitor stand supports landscape-to-portrait display rotation.
Mounting your displays on a support post above your workstation surface enables you to adjust your display height independently of your sit-to-stand workstation. You can also easily adjust position and viewing angles, for an ergonomic work environment.
Create a more ergonomic work environment at a fraction of the cost of a standing desk. Instead of replacing your conventional seated desk, you can simply place this compact sit-to-stand workstation on your existing work space and clamp the rear of the base to your desk.
The sit-stand workstation lets you optimize your desk area, and it's easy to integrate it into your current layout by simply setting it on your desk, tabletop or other stable work surface (minimum 26 in. depth).
The workstation provides lots of space for writing notes or placing accessories on its base and features a large keyboard tray that accommodates your keyboard and mouse, so it's perfect for any business or home office workspace.
StarTech.com Sit-to-Stand Workstation with Full-Motion Articulating Monitor Arm - One-Touch Height Adjustment (CDP2DVIUCP) mounting kit - for LCD display / keyboard / mouse / notebook
Mounting kit - desktop stand
Mounting Components
Tray, articulating arm, surface, base plate, pneumatic spring
68 cm x 66 cm
Tilt
-65° to 90°
Pan
360°
Lift
59.6 cm
Rotation
-90° to 90°
Adjustments
21.5 kg
Recommended Use
Recommended Display Size
12"-26"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11 kg
Material
Wood, steel
68 cm
66 cm
21.5 kg
Material
Wood, steel
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Placing / Mounting
Desktop stand
12"-26"
Tilt
-65° to 90°
Pan
360°
Lift
59.6 cm
Rotation
-90° to 90°
Adjustments
Max Load Weight
11 kg
C9J7 StarTech.com Sit-to-Stand Workstation In Stock £275.96
