StarTech.com Single Desk Mount Monitor Arm - 2 Built-in USB 3.0 Ports
Quicklinx: FW6SWS00 Mfr#: ARMSLIM2USB3
£101.60 ex VAT
£121.92 inc VAT
Free up space while creating an ergonomic work environment. This desk-mount monitor arm makes it easy to securely mount and adjust a 17" to 34" display above your desk.
  • Adjust your monitor for ideal viewing
    The single arm monitor mount extends up to 21.5" (547 mm) so it's easy to find the right viewing angle. Swivel your monitor +90/-90 degrees or tilt your screen +90/-90 degrees for comfortable viewing. You can even rotate it 180 degrees for landscape or portrait viewing.
  • One-touch height adjustment
    The slim monitor-mount arm features a mechanical spring that makes it easy to raise or lower your display, with up to 17.5" (445 mm) [AS1] of height adjustment. Adjust the tension according to the weight of your monitor for effortless movement.
  • Easy installation
    The VESA mount monitor stand is easy to install (desk C-clamp or grommet mount) and offers built-in cable management and dual USB 3.0 port passthrough for connecting your computer.
StarTech.com Desk Mount Monitor Arm with 2x USB 3.0 ports, Slim Full Motion Adjustable Single Monitor VESA Mount up to 17.6lbs (8kg) Display, Ergonomic Articulating Arm, Desk Clamp/Grommet - One-touch Adjustment (ARMSLIM2USB3) mounting kit - Slim Full-motion - for LCD display/ curved LCD display - black
Mounting kit (Slim Full-motion) - desk-mountable
Mounting Components
Articulating arm, desk clamp mount, grommet clamp
Integrated Devices
2-ports USB 3.0 hub
11.5 cm x 54.7 cm x 44.5 cm
Tilt
-90° to 90°
Swivel
-90° to 90°
Adjustments
Height, tilt, swivel
2.85 kg
Recommended Use
Recommended Display Size
17"-34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Heavy duty aluminium
Package Content
4 x M4x12 screws, 4 x washers, 4 x M5x12 screws, hex key (3mm), grommet plate, hex key (6mm), cable management clip, grommet screw
11.5 cm
54.7 cm
44.5 cm
2.85 kg
Material
Package Content
AV Furniture
Mounting kit
Mounting Components
Design
Slim Full-motion
Recommended Use
Placing / Mounting
Desk-mountable
Integrated Devices
2-ports USB 3.0 hub
Cable Management
Integrated cable management
17"-34"
Tilt
-90° to 90°
Swivel
-90° to 90°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
43.5 cm x 24 cm x 11.7 cm / 3.5 kg
