StarTech.com Serial DB9 RS232 Extender over Cat 5 - Up to 3300 ft (1000 meters)
Quicklinx: 7P1NWS00 Mfr#: RS232EXTC1GB
Type: Extender
13 In Stock
£103.75 ex VAT
£124.50 inc VAT
The RS232EXTC1GB Serial over Cat 5 Extender allows you to increase the distance of your RS232 Serial connection by up to 1000 meters (3300 feet), giving you the ability to connect serial peripheral devices up to a kilometer away from your system - an incredible 65x greater than normal RS232 serial cable length restrictions would permit.
The Extender is a cost-effective serial extension solution and completely hardware-based, eliminating the need to install additional software, allowing for a completely plug and play installation. The hardware can be setup in minutes, using Cat 5 or better Ethernet cabling.
Perfect for use in industrial monitoring and control, POS, security, medical, and traffic flow applications, the RS232 Serial over Cat 5 extender maintains the RS232 standard with support for data transfer rates of up to 230 Kbps.
StarTech.com Serial DB9 RS232 Extender over Cat 5 - Up to 3300 ft (1000 meters) - serial port extender
Serial port extender
External
United Kingdom
Data Transfer Rate
230 Kbps
Transmission Medium
CAT 5
Max Transfer Distance
1 km
External
United Kingdom
Wired
Data Transfer Rate
230 Kbps
1 km
1 x RS-232 - DB-9
7P1N StarTech.com DC Power Adapter - 9V, 2A In Stock £12.06
Type: Extender
