Mount an mSATA SSD into your standard or small form factor desktop computer, using a standard SATA host connection. The SAT32MSATPEX mSATA to SATA adapter enables you to connect a mSATA SSD to a standard SATA port, and mount the drive into any desktop expansion slot.
The adapter maximizes the speed of your computer by adding the performance of an mSATA SSD to any SATA enabled desktop computer. Allowing for faster boot time, and increased performance in regular operation.
For a hassle-free installation the adapter mounts into any new or legacy Desktop expansion slot, with support for PCI, and PCIe slots, and includes full profile and low profile brackets.
- StarTech.com SATA to mSATA SSD Adapter w/ Full and Low Profile Brackets - 2.5" SATA to Mini SATA Converter Card (SAT32MSATPEX) - storage controller - SATA 6Gb/s - PCIe
- Storage controller - plug-in card - low profile
- Bus Type
- PCIe
- Hard Drive Form Factor Compatibility
- mSATA
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Solid state drive
- 6.2 cm x 12 cm x 0.5 cm
- 40 g
- 2-year warranty
- mSATA
- Host Bus
- PCIe
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Solid state drive
- 1 x SATA 6Gb/s - mSATA
- Connections
- 1 x SATA 6Gb/s - 22 pin Serial ATA
- Included Accessories
- Low-profile bracket, full-height bracket
- FCC, RoHS
- Limited warranty - 2 years
- 6.2 cm
- 12 cm
- 0.5 cm
- 40 g
- 0 °C
- 50 °C
- 5 - 95%
