StarTech.com SATA to mSATA SSD Adapter w/ Full and Low Profile Brackets – SATA to Mini SATA
Quicklinx: 95XQWS00 Mfr#: SAT32MSATPEX
Type: Storage controller
HD Size: mSATA
Hurry, only 2 left in stock!
£15.10 ex VAT
£18.12 inc VAT
Mount an mSATA SSD into your standard or small form factor desktop computer, using a standard SATA host connection. The SAT32MSATPEX mSATA to SATA adapter enables you to connect a mSATA SSD to a standard SATA port, and mount the drive into any desktop expansion slot.
The adapter maximizes the speed of your computer by adding the performance of an mSATA SSD to any SATA enabled desktop computer. Allowing for faster boot time, and increased performance in regular operation.
For a hassle-free installation the adapter mounts into any new or legacy Desktop expansion slot, with support for PCI, and PCIe slots, and includes full profile and low profile brackets.
StarTech.com SATA to mSATA SSD Adapter w/ Full and Low Profile Brackets - storage controller - SATA 6Gb/s - PCIe
Storage controller - plug-in card - low profile
Bus Type
PCIe
Hard Drive Form Factor Compatibility
mSATA
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
6.2 cm x 12 cm x 0.5 cm
40 g
mSATA
Host Bus
PCIe
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
1 x SATA 6Gb/s - mSATA
1 x SATA 6Gb/s - 22 pin Serial ATA
Low-profile bracket, full-height bracket
FCC, RoHS
6.2 cm
12 cm
0.5 cm
40 g
50 °C
5 - 95%
95XQ StarTech.com 12in Latching SATA Cable In Stock £3.33
95XQ StarTech.com SATA to LP4 Power Cable Adapter In Stock £4.35
95XQ StarTech.com 40/44 Pin IDE to Compact Flash SSD Adapter In Stock £11.75
95XQ StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £4.32
95XQ StarTech.com 12in SATA Serial ATA Cable In Stock £3.05
95XQ StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £32.02
95XQ StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA In Stock £3.79
95XQ StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F In Stock £4.44
95XQ StarTech.com SATA to mSATA SSD Adapter w/ Full and Low Profile Brackets – SATA to Mini SATA In Stock £15.10
95XQ StarTech.com mSATA to SATA HDD / SSD Adapter – Mini SATA to SATA Converter Card In Stock £12.03
95XQ StarTech.com SATA to mSATA SSD Adapter – Port Mounted SATA to Mini SATA Converter Card In Stock £15.28
HD Size: mSATA
Price Range Ex VAT: 0 - 50
