Mount an mSATA SSD into your standard or small form factor desktop computer, using a standard SATA host connection. The SAT32MSATPEX mSATA to SATA adapter enables you to connect a mSATA SSD to a standard SATA port, and mount the drive into any desktop expansion slot.
The adapter maximizes the speed of your computer by adding the performance of an mSATA SSD to any SATA enabled desktop computer. Allowing for faster boot time, and increased performance in regular operation.
For a hassle-free installation the adapter mounts into any new or legacy Desktop expansion slot, with support for PCI, and PCIe slots, and includes full profile and low profile brackets.
- StarTech.com SATA to mSATA SSD Adapter w/ Full and Low Profile Brackets - 2.5" SATA to Mini SATA Converter Card (SAT32MSATPEX) - storage controller - SATA 6Gb/s - PCIe
- Storage controller - plug-in card - low profile
- Bus Type
- PCIe
- Hard Drive Form Factor Compatibility
- mSATA
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Solid state drive
- 6.2 cm x 12 cm x 0.5 cm
- 40 g
- 2-year warranty
- mSATA
- Host Bus
- PCIe
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Solid state drive
- 1 x SATA 6Gb/s - mSATA
- Connections
- 1 x SATA 6Gb/s - 22 pin Serial ATA
- Included Accessories
- Low-profile bracket, full-height bracket
- FCC, RoHS
- Limited warranty - 2 years
- 6.2 cm
- 12 cm
- 0.5 cm
- 40 g
- 0 °C
- 50 °C
- 5 - 95%
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.44 |
StarTech.com 24" Serial ATA Cable | In Stock | £5.18 |
StarTech.com 18" Serial ATA Cable w/R Angle | In Stock | £5.00 |
StarTech.com 18in SATA Serial ATA Cable | In Stock | £4.34 |
StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable | In Stock | £5.40 |
StarTech.com 12in Latching SATA Cable | In Stock | £6.32 |
StarTech.com SATA to LP4 Power Cable Adapter | In Stock | £5.24 |
StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F | In Stock | £7.38 |
StarTech.com 12in SATA Serial ATA Cable | In Stock | £4.36 |
StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F | In Stock | £6.02 |
StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure | In Stock | £37.78 |
StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA | In Stock | £5.12 |
StarTech.com 12in LP4 to 2x Right Angle Latching SATA Power Y Cable Splitter - 4 Pin Molex to SATA | In Stock | £4.30 |
StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F | In Stock | £5.40 |
StarTech.com mSATA to SATA HDD / SSD Adapter – Mini SATA to SATA Converter Card | In Stock | £14.35 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £18.53 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £19.62 |
StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter | In Stock | £43.44 |
StarTech.com M.2 NGFF to SATA Adapter | In Stock | £23.25 |
StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP | In Stock | £23.99 |
StarTech.com Dual M.2 NGFF SATA Adapter w/ RAID - 2x M.2 SSDs to 2.5in SATA | In Stock | £35.63 |
StarTech.com M.2 SATA Enclosure with USB-C | In Stock | £28.99 |
StarTech.com 6" SATA Power Y Splitter Cable | In Stock | £7.38 |
StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter | In Stock | £23.56 |
StarTech.com M.2 to U.2 Adapter | In Stock | £26.40 |
StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe | In Stock | £152.39 |
StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 | In Stock | £28.73 |
