StarTech.com SATA to mSATA SSD Adapter – Port Mounted SATA to Mini SATA Converter Card
Quicklinx: 964ZWS00 Mfr#: SAT32MSATM
Turn a SATA host connection into an mSATA port. The SAT32MSATM SATA to mSATA adapter enables you to connect an mSATA SSD to any standard SATA port, ideal for connecting an mSATA SSD to an ITX computer systems that does not have an mSATA port.
The adapter enables you to harness the speed of upgrading to a faster drive by connecting an mSATA SSD to any SATA-enabled desktop computer. Allowing for faster boot time, and increased performance in regular operation.
For a hassle-free, tool-less installation where space may be limited the adapter connects and mounts directly into the SATA port.
StarTech.com SATA to mSATA SSD Adapter - Port Mounted SATA to Mini SATA Drive Converter Card - 7-Pin SATA to mSATA Adapter Converter Card (SAT32MSATM) - storage controller - SATA 6Gb/s
Storage controller - internal
Hard Drive Form Factor Compatibility
mSATA
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
17 cm x 14.2 cm x 3 cm
14 g
mSATA
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
1 x SATA 6Gb/s - mSATA
1 x SATA 6Gb/s - 7 pin Serial ATA , 1 - 4 PIN internal power
Power 15 pin SATA to 4 pin adapter
FCC, RoHS
17 cm
14.2 cm
3 cm
14 g
5 °C
50 °C
20 - 80%
964Z StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
964Z StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.40
964Z StarTech.com 12in Latching SATA Cable In Stock £5.40
964Z StarTech.com 12in SATA Serial ATA Cable In Stock £4.36
964Z StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £6.02
964Z StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £37.78
964Z StarTech.com 1 Port SATA to eSATA Slot Plate Bracket In Stock £6.50
964Z StarTech.com mSATA to SATA HDD / SSD Adapter – Mini SATA to SATA Converter Card In Stock £14.35
964Z StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £18.53
964Z StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe In Stock £152.39
