StarTech.com SATA Right Side Angle Cable - 12ins
Quicklinx: 8GTRWS00 Mfr#: SATA12RSA1
Make a right side-angled connection to your SATA drive, for installation in narrow spaces. The SATA12RSA1 Right Side-Angled SATA Cable (12-inch) features one straight and one right side-angled (7-pin) data receptacle, which positions the cable so that it runs parallel to the drive ports - ideal for connectivity in narrow spaces, enabling installation of the drive as needed within the system case.
The cable also features a flexible low profile design that helps improve airflow and reduce clutter in your computer case, which helps keep the case clean and cool.
Constructed of only top quality materials and designed for optimum performance and reliability this 12" SATA cable supports full SATA 3.0 bandwidth (up to 6Gbps) when used with SATA 3.0 compliant drives.
StarTech.com SATA to Right Side Angle SATA Serial ATA Cable - SATA cable - 30.48 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Right-angled connector
Length
30.48 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: 25S22M2NGFFR, 25SAT22MSAT, MSAT2SAT3, S322M225R, S32M2NGFFPEX, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SAT32MSATM, SAT32MSATPEX
Storage Cable Type
SATA cable
Interface Speed
American Wire Gauge (AWG)
26
Length
30.48 cm
Red
Connector
RoHS
