StarTech.com SATA Raspberry Pi Adapter
Quicklinx: CKZ0WS00 Mfr#: PIB2S31
£20.48 ex VAT
£24.57 inc VAT
Connect any SATA device to your development board, to increase its data storage capacity and performance. Increase the data storage capacity of your Raspberry Pi or other development board, by connecting it directly to a SATA-based drive. Perfect for custom projects and applications, this USB to SATA converter supports all models of Raspberry Pi as well as other development boards.
This convenient USB 2.0 SATA converter lets you overcome data storage limitations by enabling you to connect a SATA drive or SATA optical drive through your board's USB-A port. This enables you to access a wide variety of storage formats including solid-state drives or hard drives, DVD-ROM drives or CD-ROM drives.
The USB to SATA converter integrates seamlessly with your existing development board. It's the perfect addition for development-board based applications such as surveillance, media players and servers, digital signage and IoT/automation solutions.
Compatible with SATA I, SATA II and SATA III drives, the converter is easy to install, and doesn't require any device driver installation. It comes with a USB cable and all mounting accessories, including standoffs, so integrating it with your Raspberry Pi is fast and easy.
StarTech.com USB to SATA Converter for Raspberry Pi and Development Boards - storage controller - SATA 6Gb/s - USB 2.0
Storage controller - internal
Bus Type
USB 2.0
Red
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, CD drive, DVD drive, solid state drive
Channel Qty
1
2.3 cm x 6.6 cm x 1.1 cm
23 g
Host Bus
USB 2.0
Red
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Channel Qty
1
Renesas µPD720231A
1 x SATA 6Gb/s - SATA
1 x USB 2.0 - mini-USB Type B
1 x micro-USB cable
USB powered
Mounting Kit
Included
MTBF
6,481,043 hours
2.3 cm
6.6 cm
1.1 cm
23 g
5 °C
50 °C
15 - 90%
CKZ0 StarTech.com SATA to mSATA SSD Adapter w/ Full and Low Profile Brackets – SATA to Mini SATA In Stock £28.62
CKZ0 StarTech.com mSATA to SATA HDD / SSD Adapter – Mini SATA to SATA Converter Card In Stock £12.03
CKZ0 StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £16.94
CKZ0 StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £38.35
CKZ0 StarTech.com USB 3.1 mSATA Drive Enclosure In Stock £25.20
CKZ0 StarTech.com mSATA Raspberry Pi Adapter In Stock £17.81
CKZ0 StarTech.com M.2 SATA Raspberry Pi Adapter In Stock £21.05
Price Range Ex VAT: 0 - 50
