Product
StarTech.com Samsung Galaxy MHL Adapter Converter - 11 Pin Micro USB to HDMI
Quicklinx: 90WPWS00 Mfr#: MHD2HDF11
Connect your MHL­enabled Samsung Galaxy mobile device to an HDTV, monitor or projector using HDMI. The MHD2HDF11 Samsung Galaxy MHL Adapter is an active Micro USB to HDMI Video Adapter that enables you to connect a Samsung Galaxy 11 Pin MHL 2.0-enabled smart phone or tablet (S3, S4, Note 2, or future MHL11 pin devices) to a non-MHL-enabled HDTV, monitor, or projector through HDMI.
The adapter makes it easy to connect your MHL 2.0-enabled smartphone to a large screen display and share your photos, video (with supporting audio), and other content stored on your mobile device on a large screen. For added convenience the mobile adapter device supports RCP (Remote Control Protocol), which allows you to use your television remote control to operate your smartphone, on televisions that are equipped with CEC or Anynet+.
For maximum video and audio quality, this 11-pin MHL HDMI adapter supports 1080p output resolution and 7.1-channel digital audio, which helps deliver an optimized multimedia experience. To prevent battery drain, the compact adapter features a Micro USB port on the side, that lets you charge your mobile device while it's in use.
This compact, active adapter offers a Micro USB port on the side, for the added benefit of simultaneously charging your connected mobile device, so it is always ready to use.
StarTech.com Samsung Galaxy MHL Adapter Converter - external video adapter - SiI9292CNUC - black
External video adapter
Bus Type
Mobile High-Definition Link (MHL) (11 pin Micro-USB)
Graphics Engine
SiI9292CNUC
Max Resolution
1920 x 1080
HDMI , USB 2.0
2.5 cm 1.1 cm
Length
18 cm
Enclosure Colour
2 years warranty
Bus Type
Graphics Engine
SiI9292CNUC
Max Resolution
1920 x 1080
HDMI , USB 2.0
USB powered, USB Pass-Through
Plug and Play, FCC, RoHS
2.5 cm
1.1 cm
Length
18 cm
17 g
Enclosure Colour
45 °C
90WP StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.08
90WP StarTech.com 10 ft HDMI to DVI-D Cable - M/M In Stock £8.58
