Product
StarTech.com Rugged Hard Drive Enclosure
Quicklinx: B7JCWS00 Mfr#: S251BRU33
Type: Storage enclosure
HD Size: 2.5"
6 in stock
£28.05 ex VAT
£33.66 inc VAT
Standard delivery Delivered within 3-5 working days
Gear up for the field with portable hard drive protection. This rugged drive enclosure redefines data protection for on-the-go professionals. The military-grade construction protects your sensitive data from harsh field conditions. It makes sure you're equipped for unexpected challenges with a ruggedized water, dust, vibration and shock resistant enclosure.
Keep your data safe and secure even through sudden downpours or dust storms. The robust enclosure provides superior water and dust resistance with an IP54 rating.
The rugged drive enclosure is enveloped in a silicone protective sleeve, and engineered to help protect your drive from accidental and unexpected shock, vibrations, and drops. It's Military MIL-STD-810G rated and test-proven to withstand drops of up to 4 meters (13 feet). It was drop tested using a solid-state drive in the enclosure.
Wherever you go, the rugged drive enclosure delivers reliable data protection, inside and out, with a tough-wearing exterior casing. The flexible shock-resistant silicone sleeve hugs the entire perimeter to provide an extra measure of protection, absorbing the impact of accidental bumps, rough baggage handling or drops. Inside, an extra layer of silicone provides added stability and security.
It's easy to turn your 2.5in SATA III (6Gbps) solid-state drive or hard drive into external storage. Simply remove the silicone sleeve, open the latch to insert your 2.5" drive into the rugged enclosure, and plug the included USB cable into the computer or hub USB port. There are no screws or tools needed.
Save time in the field, by storing and transferring content quickly. Enhanced with UASP (USB Attached SCSI Protocol), this rugged drive enclosure performs with a 70% faster read speed and 40% faster write speed over conventional USB 3.0, when paired with a UASP-enabled host controller.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com enclosure, and a SATA III (6Gbps) solid state drive.
  • Industry recognized protection against water and dust, with an IP54 rating
  • Drop tested for 4 meters (13 feet)
  • Data protection inside and out
  • Install your drive with ease, with a tool-less design
  • Store and transfer content quickly
StarTech.com Rugged Hard Drive Enclosure - USB 3.0 to 2.5in SATA 6Gbps - storage enclosure - SATA 6Gb/s - SATA 6Gb/s, USB 3.0
Storage enclosure - external
Bus Type
SATA 6Gb/s, USB 3.0
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
Max Storage Devices Qty
1
Power Source
USB bus
Windows 8, Apple MacOS X 10.8 or later
11.3 cm x 14.5 cm x 2.7 cm
200 g
2 years warranty
P/N: HB30C1A1CPD, HB30C3APD, HB30C3APDW, HB30C4AFPD
2.5"
Hard Drive Maximum Height
9.5 mm
Host Bus
SATA 6Gb/s, USB 3.0
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
1
ASMedia ASM1153E
Bays
1 x internal - 2.5"
1 x SATA 6Gb/s - 22 pin Serial ATA
1 x USB 3.0 - 9 pin Micro-USB Type B
1 x USB 3.0 cable - external
USB powered, tested with up to 2TB 7200 RPM 2.5" hard drives
FCC, RoHS, MIL-STD-810G
Power Source
USB bus
11.3 cm
14.5 cm
2.7 cm
200 g
-40 °C
85 °C
20 - 95%
B7JC StarTech.com 3 ft Black SuperSpeed USB 3.0 Cable A to Micro B - M/M In Stock £6.40
B7JC StarTech.com 3 ft SuperSpeed USB 3.0 Cable A to Micro B In Stock £6.28
B7JC StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to Micro B In Stock £5.91
B7JC StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M In Stock £6.10
B7JC StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £8.21
B7JC StarTech.com 1m (3ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £7.03
B7JC StarTech.com 0.5m (20in) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £6.17
B7JC StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £5.26
B7JC StarTech.com 10ft Slim Micro USB 3.0 Cable In Stock £10.51
B7JC StarTech.com Rugged Hard Drive Enclosure In Stock £28.05
HD Size: 2.5"
Price Range Ex VAT: 0 - 50
