StarTech.com RS422 RS485 Serial DB9 to Terminal Block Adapter
Quicklinx: 6PF9WS00 Mfr#: DB92422
41 In Stock
£11.75 ex VAT
£14.10 inc VAT
The DB92422 DB 9 to Terminal Block adapter converts an RS-422 or RS-485 DB 9 male serial connector to a terminal block connector.
The 5-pin 3.5mm Terminal Block connector supports screw-type wiring to meet the standard for industrial wiring applications.
StarTech.com RS422 RS485 Serial DB9 to Terminal Block Adapter - Serial adapter - 5 pin terminal block to DB-9 (M) - black - DB92422 - serial adapter - 5 pin terminal block to DB-9
Serial adapter
Connector
Connector (Second End)
9 pin D-Sub (DB-9) - male
1-year warranty
P/N: PCI2S232485I, PCI2S4851050
Serial adapter
Connector
FCC, RoHS
1-year warranty
6PF9 StarTech.com 1 Port Metal Industrial USB to RS422/RS485 Serial Adapter with Isolation In Stock £108.14
6PF9 StarTech.com 6 ft Professional RS422/485 USB Serial Cable Adapter with COM Retention In Stock £60.96
