Easily convert an RS232 serial signal (-12 to +12V) to a transistor-transistor logic signal (0 to +5V). This RS232 to TTL converter lets you connect devices that use RS232 serial ports to devices that only communicate using transistor-transistor logic (TTL) signals. It's a convenient and cost-effective solution to convert RS232 into TTL, so you can connect equipment together based on your devices signal requirements.
This serial converter is ideal for short distance communication between two devices, and can be used to connect your computer to microcontroller-based embedded systems and industrial robotics. The reliable converter easily turns high voltage (-12 to +12V) RS232 signals into low voltage (0 to +5V) TTL signals, and provides bidirectional data communication at baud rates up to 115.2 Kbps.
With a small-footprint design and no software or drivers required, you can easily pair your TTL equipment with virtually any device that features an RS232 DB9 serial port, such as computers, and industrial control equipment. Plus, if your host device doesn't feature a native RS232 port, this versatile converter can be coupled with a USB to RS232 serial adapter (SKU: ICUSB232D - sold separately).
The converter delivers dependable performance at extended operating temperatures (-40°C to 85°C), so it integrates nicely into a variety of workplace settings.
- StarTech.com RS232 to TTL Serial Converter - serial adapter - RS-232C
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- Serial RS-232C
- 3.4 cm x 6.3 cm x 1.5 cm
- 25 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 115.2 Kbps
- Black
- 2-year warranty
- Serial adapter
- Form Factor
- External
- Serial RS-232C
- Connectivity Technology
- Wired
- RS-232
- 115.2 Kbps
- Flow control, full duplex mode
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x RS-232 (TTL) - 9 pin D-Sub (DB-9)
- FCC, RoHS
- Black
- 3.4 cm
- 6.3 cm
- 1.5 cm
- 25 g
- Limited warranty - 2 years
- -40 °C
- 85 °C
- 5 - 95%
