StarTech.com Replacement 70mm TX3 Dual Ball Bearing CPU Cooler Fan
Reduced Price - Whilst Stocks Last!
Quicklinx: 6BF3WS00 Mfr#: FAN7X10TX3
This 70mm TX3 Dual Ball Bearing CPU Cooler Fan is a cost-effective replacement fan for standard CPUs as well as many different types of 1U or low profile CPU coolers that use a 70mm fan.
For peace of mind, the CPU cooling fan features a Tachometer pin on the TX3 motherboard connector that provides the host system with fan operating status, while a dual ball bearing design helps provide smooth operation and longer (fan) lifespan.
StarTech.com Replacement 70mm TX3 Dual Ball Bearing CPU Cooler Fan case fan
Case fan
Fan Diameter
70 mm
Fan Height
10 mm
Fan Bearing
Dual ball bearing
Rotation Speed
3500 rpm
Air Flow
21.3 cfm
Power Connector
3-pin plug
Product Material
Plastic
Fan speed monitoring
Case fan
Product Material
Plastic
Heatsink & Fan
Fan Diameter
70 mm
Fan Height
10 mm
Fan Bearing
Dual ball bearing
Rotation Speed
3500 rpm
Air Flow
21.3 cfm
Power Connector
3-pin plug
UL, RoHS
Sound Emission
33 dB
6BF3 StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable In Stock £2.76
