Turn a 2.5in SATA drive into a front bay mounted removable HDD backup solution. The SAT2510U3REM Removable 2.5" SATA HDD Backup System/Mobile Rack turns a 2.5" SATA HDD/SSD drive into a removable hard drive that can also be used externally as a normal USB 3.0 enclosure.
This 2.5" SATA removable hard drive bay can be mounted into any 3.5" or 5.25" front bay, to provide a hot-swap capable mobile rack. Drives can then be easily installed and removed from the computer system without having to open the computer case every time, providing a convenient method of creating backups that can then be removed for safe keeping/archiving.
When outside of the drive bay, the enclosure can be used as a standard external USB 3.0 hard drive with up to 5 Gbps of data transfer bandwidth (10x more than USB 2.0). This makes the removable 2.5" hard drive bay an excellent accessory for people working with very large files and need to take them on the road.
For even more versatility, StarTech.com offers the SAT2510U3S, an extra 2.5in SATA Hard Drive Enclosure for the SAT2510U3REM, providing multiple enclosures that can be swapped in and out of the main computer. The SAT2510U3REM is also backward compatible with the USB 2.0 model, SAT2510U2S.
- StarTech.com Removable 2.5" SATA HDD Backup System for 3.5/5.25" Bay - storage mobile rack - USB 3.0 / SATA 6Gb/s - SATA 6Gb/s, USB 3.0
- Storage mobile rack
- Bus Type
- Black
- Expansion Bays
- 1 x internal - 2.5" x 1/8H , 1 x front accessible - 5.25"/ 3.5" shared
- Compatible Bay
- 1 5.25" , 1 3.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Supported Interface
- SATA-600
- Drive Connector
- 22 pin Serial ATA
- Bay Connector
- 7 pin Serial ATA
- Interface
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Max Storage Devices Qty
- 1
- Product Material
- Plastic, aluminium
- System Requirements
- Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- 14.58 cm x 16.48 cm x 4.16 cm
- 410 g
- 2-year warranty
- Designed For
- P/N: S251BU31REMD
- 2.5"
- Host Bus
- Product Material
- Black
- SATA-600
Storage Controller
- Interface
- 6 Gbit/s
- Supported Devices
- 1
- Processor
- ASMedia ASM1053 / ASM1456
- Bays
- 1 x SATA 6Gb/s - SATA combo , 1 x - Micro-USB Type B
- Connections
- 1 x USB 3.0 - 9 pin USB Type A , 1 storage - Serial ATA-600 - 7 pin Serial ATA
- Compatible Bay
- 1 x external 5.25" , 1 x external 3.5"
- Included Accessories
- 3.5" bay adapter, 5.25" bay adaptor
- Cables Included
- 1 x USB 3.0 cable , 1 x Serial ATA cable , 1 x power 15 pin SATA to 4 pin adapter , 1 x floppy adapter
- Mounting Kit
- Included
- FCC, RoHS
- OS Required
- Limited warranty - 2 years
- 14.58 cm
- 16.48 cm
- 4.16 cm
- 410 g
- 0 °C
- 40 °C
- 5 - 95%
- Designed For
- P/N: S251BU31REMD
