Add a redundant or replacement power supply to the ETCHS2U media converter chassis. The ETCHS2UPSU Redundant / Replacement 200W Chassis Power Module for ETCHS2U lets you add a redundant power supply, or keep a replacement power supply on hand for your ETCHS2U media converter chassis.
A hot-swappable, modular design allows a second media converter redundant power supply to be removed or installed while the chassis is still operating, avoiding unnecessary downtime. The power supply is installed using thumbscrews for a quick and easy installation that doesn't require additional tools.
- StarTech.com Redundant 200W Media Converter Chassis Power Supply Module - power supply - hot-plug / redundant - 200 Watt
- Power supply - hot-plug / redundant - active Power Factor Correction (PFC) - plug-in module
- 1.3 kg
- Input Voltage
- AC 115/230 V
- Output Voltage
- 12 V
- Power Capacity
- 200 Watt
- 15.9 cm x 16 cm x 4.2 cm
- 2-year warranty
- Designed For
- P/N: ETCHS2U
- Input Voltage
- AC 115/230 V
- Input Voltage Range
- AC 110 - 240 V
- Frequency Required
- 47 - 63 Hz
- Output Voltage
- 12 V
- Power Capacity
- 200 Watt
- Circuit Protection
- Fuse
- Efficiency
- 90%
- MTBF
- 65,000 hours
- On/off switch
- UL, RoHS
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 5 - 90% (non-condensing)
- 15.9 cm
- 16 cm
- 4.2 cm
- 1.3 kg
- Shipping Weight
- 1.5 kg
- Designed For
- P/N: ETCHS2U
