StarTech.com Redundant 200W Media Converter Chassis Power Supply Module for ETCHS2U
Quicklinx: 8GTMWS00 Mfr#: ETCHS2UPSU
Hurry, only 1 left in stock!
£261.10 ex VAT
£313.32 inc VAT
Add a redundant or replacement power supply to the ETCHS2U media converter chassis. The ETCHS2UPSU Redundant / Replacement 200W Chassis Power Module for ETCHS2U lets you add a redundant power supply, or keep a replacement power supply on hand for your ETCHS2U media converter chassis.
A hot-swappable, modular design allows a second media converter redundant power supply to be removed or installed while the chassis is still operating, avoiding unnecessary downtime. The power supply is installed using thumbscrews for a quick and easy installation that doesn't require additional tools.
StarTech.com Redundant 200W Media Converter Chassis Power Supply Module for ETCHS2U (ETCHS2UPSU) - power supply - hot-plug / redundant - 200 Watt
Power supply - hot-plug / redundant - active Power Factor Correction (PFC) - plug-in module
1.3 kg
Input Voltage
AC 115/230 V
Output Voltage
12 V
Power Capacity
200 Watt
15.9 cm x 16 cm x 4.2 cm
P/N: ETCHS2U
Input Voltage
AC 115/230 V
Input Voltage Range
AC 110 - 240 V
Frequency Required
47 - 63 Hz
Output Voltage
12 V
Power Capacity
200 Watt
Circuit Protection
Fuse
Efficiency
90%
MTBF
65,000 hours
On/off switch
UL, RoHS
60 °C
5 - 90% (non-condensing)
15.9 cm
16 cm
4.2 cm
1.3 kg
Shipping Weight
1.5 kg
P/N: ETCHS2U
Type: Power Supplies
Stock Status: In stock
