StarTech.com Rackmount KVM Console - 8 Ports with 17" LCD Monitor
Quicklinx: F2GJWS00 Mfr#: RKCONS1708K
Type: KVM switch
Ports: 8
Hurry, only 3 left in stock!
£886.07 ex VAT
£1,063.28 inc VAT
Providing centralized control of up to eight servers, this 8-port rackmount KVM console gives you easy access to your systems. With a minimal footprint, it mounts in a server rack or cabinet using only 1U of rack space.
The 1U rackmount console features a built-in keyboard, a touchpad for intuitive control, and a 17-inch LCD display that supports resolutions up to 1280x1024.
This 8-port KVM console comes with everything you need to set up right out of the box: 8 VGA KVM Cables; Mounting Rails; M5 Cage Nuts and Screws.
With direct access to eight systems or servers, the 8-port KVM module gives you the flexibility you need to easily integrate the console into your existing server infrastructure.
Rack consoles provide convenient, rack-mounted control options for single servers or the entire server room. KVM consoles include LCD display, keyboard, and trackpad, all sliding into 1U of rack space.
StarTech.com Rackmount KVM Console - 8 Ports with 17" LCD Monitor - KVM console - 17"
KVM console - 17"
KVM Switch
PS/2, USB - 8 ports
Keyboard, touchpad, 8 port KVM switch
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Input Connectors
VGA
44.8 cm x 52.56 cm x 4.25 cm
Height (Rack Units)
1U
13.3 kg
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Display Type
KVM console / TFT active matrix
Diagonal Size
17"
Built-in Devices
8 port KVM switch
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Height (Rack Units)
1U
13.3 kg
Input
Keyboard, touchpad
KVM
KVM switch - 8 ports
Keyboard / Mouse Interface
PS/2, USB
Max Resolution
1280 x 1024 @ 60 Hz
8 x VGA , 2 x USB 2.0 (Type A) , 2 x PS/2 , VGA output , Daisy chain port (HD-15)
8 x M5 cage nuts, 8 x M5 screws, 2 x mounting rails
8 x keyboard / mouse / video cable - 1.83 m
Rack Mounting Kit
Included
MTBF
50,000 hour(s)
AC 120/230 V
13 Watt
Shipping Weight
19 kg
10 - 80% (non-condensing)
F2GJ StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £7.39
F2GJ StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £36.40
F2GJ StarTech.com 19in Cable Management Panel In Stock £22.86
F2GJ StarTech.com 8 Port KVM Console for Server Rack - 19in In Stock £966.60
F2GJ StarTech.com Single Server KVM Console for Server Rack -19" In Stock £650.98
F2GJ StarTech.com 16 port KVM VGA Console with KVM Switch - 19" In Stock £1,161.96
F2GJ StarTech.com 17" Dual Rail Rackmount KVM Console with 1080p In Stock £1,051.60
F2GJ StarTech.com Rackmount KVM Console - 8 Ports with 17" LCD Monitor In Stock £886.07
Type: KVM switch
Ports: 8
Price Range Ex VAT: 750 - 1000
