StarTech.com Rack Bracket For SV431/D
Quicklinx: 3ZNQWS00 Mfr#: SV431RACK
Mount a 1U SV431 Series KVM switch into your server rack or cabinet. The SV431RACK 1U rack mount brackets let you mount your SV431 / SV431D KVM switch into a rack or cabinet.
Designed for simple installation and maximum server rack space-efficiency, the rack brackets include a cable support bracket that reduces stress on KVM cables and switch connectors.
StarTech.com 1U Rack Mount Brackets for KVM Switch (SV431 Series) - rack bracket kit - 1U
Rack bracket kit
Height (Rack Units)
1U
P/N: SV565FXDUSA, SV431DUSBU, SV431DVIUAHR, SV431DVIUAGB, SV431DVIUA, SV431DUSBGB, SV431DUSB, SV431HGB, SV431USBGB, SV431GB, SV431DGB, SV431USB, SV431H, SV431, SV431D
Rack bracket kit
Height (Rack Units)
1U
Rack Mounting Kit
Included
Limited warranty - lifetime
StarTech.com 4 Port DVI USB KVM Switch with Audio and 2 port USB 2.0 Hub, USB DVI KVM Console Extender w/ Serial & Audio Over MM Fiber - 2km, USB PS/2 KVM switch with OSD , StarTech.com StarView SV431, SV431D
