Create a wireless hot-spot from a wired network connection to share with any WiFi-enabled device. The AP150WN1X1U Wireless N Travel Router lets you create a portable WiFi hot-spot from a wired network connection to share with all of your wireless devices including tablets, laptops / Ultrabooks and smartphones.
Designed for mobility, this USB-powered pocket router can travel with you anywhere, powered using any USB wall charger or USB port on your laptop / tablet.
Support for several operating modes help you create, share or extend a wireless connection while traveling between hotel rooms, conference centers or boardrooms. Easily choose between Access Point, Router and Repeater / WISP (Wireless Internet Service Provider) modes using the switch on the side of the router and directly configure using any wireless device with a web browser.
Support for Wireless N data rates (backward compatible with 802.11b/g) gives you the speed you need to get your work done faster, with WPA2 authentication to keep your connection secure.
- StarTech.com Wireless N WiFi Travel Router / Access Point / Repeater - wireless router - Wi-Fi
- Wireless router
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 150 Mbps
- Remote Management Protocol
- HTTP
- Repeating mode, Access Point operational mode, USB powered
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Black
- 3.1 cm x 1.5 cm x 8.4 cm
- 60 g
- 2-year warranty
- Wireless router
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 150 Mbps
- HTTP
- Encryption Algorithm
- WPA, WEP
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, FCC, RoHS
- Status Indicators
- Power, wireless
Line Properties
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, 16 QAM
- 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A (power only)
- Enclosure Colour
- Black
- Included Accessories
- Carrying case
- Cables Included
- 1 x USB extension cable , 1 x network cable
- 3.1 cm
- 1.5 cm
- 8.4 cm
- 60 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90%
