StarTech.com Portable Wireless N WiFi Travel Router / Access Point / Repeater - USB Powered
Quicklinx: 9KMSWS00 Mfr#: AP150WN1X1U
  • IEEE 802.11n
Create a wireless hot-spot from a wired network connection to share with any WiFi-enabled device. The AP150WN1X1U Wireless N Travel Router lets you create a portable WiFi hot-spot from a wired network connection to share with all of your wireless devices including tablets, laptops / Ultrabooks and smartphones.
Designed for mobility, this USB-powered pocket router can travel with you anywhere, powered using any USB wall charger or USB port on your laptop / tablet.
Support for several operating modes help you create, share or extend a wireless connection while traveling between hotel rooms, conference centers or boardrooms. Easily choose between Access Point, Router and Repeater / WISP (Wireless Internet Service Provider) modes using the switch on the side of the router and directly configure using any wireless device with a web browser.
Support for Wireless N data rates (backward compatible with 802.11b/g) gives you the speed you need to get your work done faster, with WPA2 authentication to keep your connection secure.
StarTech.com Wireless N WiFi Travel Router / Access Point / Repeater - wireless router - Wi-Fi
Wireless router
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Remote Management Protocol
HTTP
Repeating mode, Access Point operational mode, USB powered
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
3.1 cm x 1.5 cm x 8.4 cm
60 g
Wireless router
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
HTTP
Encryption Algorithm
WPA, WEP
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, FCC, RoHS
Status Indicators
Power, wireless
Line Properties
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 16 QAM
1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A (power only)
Enclosure Colour
Carrying case
1 x USB extension cable , 1 x network cable
3.1 cm
1.5 cm
8.4 cm
60 g
10 - 90%
Expand your network
9KMS StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R In Stock £12.77
