StarTech.com Portable USB C to HDMI Adapter with Keychain
Quicklinx: FN5PWS00 Mfr#: CDP2HDFC
USB Type-C Video Converter 4K 30Hz Built-In Flex Cable Mac & Windows . This compact USB-C to HDMI adapter offers an ultra-portable solution for connecting your USB Type-C laptop or other device with a USB 3.1 Type-C port to a 4K HDMI monitor or display. The adapter is equipped with a removable, quick-connect keychain ring that easily attaches to your laptop or projector bag, maximizing portability.
Perfect Travel Companion
This lightweight USB-C video converter can easily be taken with you wherever you go. It conveniently attaches to your carrying case and is small enough to fit in your pocket, making it ideal for BYOD (Bring Your Own Device) applications at the office or road warriors who need to connect on the go.
It's the perfect solution for:
Delivering high-resolution presentations while in the office or traveling
Connecting your smartphone or tablet to an HDMI monitor
Hot-desking environments
Keep Your Adapter with You
Avoid misplacing your display adapter with the attached keychain that securely snaps to your carrying case so you can always keep it with your devices; the keychain can easily be removed or reattached to the adapter so you can customize it to your preference and need. The adapter also features a built-in 1.3 in. flex cable that has a folding design, adding to the compact form factor.
Plug-and-Play Connectivity
To ensure a hassle-free connection, this video adapter works with all your Mac and Windows USB Type-C devices and is also compatible with Thunderbolt 3. It requires no additional software or drivers, supporting true plug-and-play connectivity.
CDP2HDFC is backed by a StarTech.com 3-year warranty and free lifetime technical support.
  • Perfect travel companion
    This lightweight converter can easily be taken with you wherever you go. It conveniently attaches to your carrying case and is small enough to fit in your pocket, making it ideal for BYOD applications at the office or road warriors who need to connect on the go.
  • Keep your adapter with you
    Avoid misplacing your display adapter with the attached keychain that securely snaps to your carrying case so you can always keep it with your devices; the keychain can easily be removed or reattached to the adapter so you can customize it to your preference and need. The adapter also features a built-in flex cable that has a folding design, adding to the compact form factor.
StarTech.com Compact USB C to HDMI Adapter, 4K 30Hz USB Type-C to HDMI 1.4 Video Display Converter with Keychain Ring, USB-C DP Alt Mode to HDMI Monitor Dongle, Thunderbolt 3 Compatible - USB-C Keychain Adapter (CDP2HDFC) - adapter - HDMI / USB
Cable
Adapter - HDMI / USB
Max Output Resolution
3840 x 2160 - 30 Hz
Connectors
24 pin USB-C - male
Connectors (Second End)
HDMI - female
4K support
3-year warranty
Cable Type
Adapter 4K support
Interface Supported
HDMI / USB
7.1 PCM audio channel support, Realtek RTD2171U chipset
Adapters & Converters
3840 x 2160
Refresh Rate
30 Hz
Apple MacOS, Microsoft Windows
Connectors
24 pin USB-C - male
19 pin HDMI Type A - female
FCC, RoHS, WEEE, REACH
4.8 cm
3.2 cm
1.4 cm
17 g
Shipping Width
21.8 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
21.5 g
Limited warranty - 3 years
