Store your servers, network and telecommunications equipment in a portable, rolling server rack. This 9U portable server rack lets you store your server, network and telecommunications equipment in a sturdy mobile rack that has a fixed depth of 23 inches.
With built-in handles and four swiveling casters, this mobile rack is easy to transport around your server room, office or studio. Its increased mobility makes this cabinet the ideal solution for telecommunication racks that need to interface with different equipment around your workspace.
The server rack features heavy-gauge mounting rails to ensure a stable installation platform. This durable 4-post rack supports a static loading capacity of up to 220 lb (99.8 kg), and is compliant with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494), providing a universal design that's compatible with most rack equipment.
Save time and hassle with a rack that's easy to put together. With its easy four-step assembly process, you can set this portable rack up in minutes.
- StarTech.com Portable Server Rack with Handles - Rolling Cabinet - 9U - rack - 9U
- Product Type
- Rack
- Package Content
- 2 lockable casters, Phillips screwdriver, 2 casters, cage nut tool, 32 x M5 screws, 24 x M3 screws, Phillips bit, 16 x M5 bracket screws, 30 x M5 panel screws, 30 x M5 cage nuts
- Black
- Rack Size
- 23"
- Height (Rack Units)
- 9U
- Product Material
- Steel
- 60.4 cm x 51.9 cm x 48.33 cm
- 27.2 kg
- 4 post rack mountable
- 2 years warranty
- Product Type
- Rack
- Product Material
- Steel
- Package Content
- Rack Size
- 23"
- 9U
- 60.4 cm
- 51.9 cm
- 48.33 cm
- 27.2 kg
- Inner Dimensions
- 45 cm x 41.73 cm
- Black
- Weight Limit
- 544 kg
- Mounting Kit
- Included
- Wheels Qty
- 4
- Limited warranty - 2 years
StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet | In Stock | £15.74 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £77.58 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £30.39 |
StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails | In Stock | £81.93 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £14.19 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £33.10 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £26.81 |
StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £7.25 |
StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £12.01 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £102.30 |
