StarTech.com Portable Server Rack - 9U
Quicklinx: BP74WS00 Mfr#: RK960CP
Depth (mm): 51.9cm
Width (mm): 60.4cm
Hurry, only 1 left in stock!
£237.26 ex VAT
£284.71 inc VAT
Store your servers, network and telecommunications equipment in a portable, rolling server rack. This 9U portable server rack lets you store your server, network and telecommunications equipment in a sturdy mobile rack that has a fixed depth of 23 inches.
With built-in handles and four swiveling casters, this mobile rack is easy to transport around your server room, office or studio. Its increased mobility makes this cabinet the ideal solution for telecommunication racks that need to interface with different equipment around your workspace.
The server rack features heavy-gauge mounting rails to ensure a stable installation platform. This durable 4-post rack supports a static loading capacity of up to 220 lb (99.8 kg), and is compliant with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494), providing a universal design that's compatible with most rack equipment.
Save time and hassle with a rack that's easy to put together. With its easy four-step assembly process, you can set this portable rack up in minutes.
StarTech.com Portable Server Rack with Handles - Rolling Cabinet - 9U rack - 9U
Rack
Package Content
2 lockable casters, Phillips screwdriver, 2 casters, cage nut tool, 32 x M5 screws, 24 x M3 screws, Phillips bit, 16 x M5 bracket screws, 30 x M5 panel screws, 30 x M5 cage nuts
Rack Size
23"
Height (Rack Units)
9U
Product Material
Steel
60.4 cm x 51.9 cm x 48.33 cm
27.2 kg
4 post rack mountable
Rack
Product Material
Steel
Package Content
Rack Size
23"
Height (Rack Units)
9U
60.4 cm
51.9 cm
48.33 cm
27.2 kg
Inner Dimensions
45 cm x 41.73 cm
Weight Limit
544 kg
Mounting Kit
Included
Wheels Qty
4
BP74 StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £15.74
BP74 StarTech.com 12U Adjustable 4 Post Server Equipment Open Frame Rack Cabinet In Stock £188.46
BP74 StarTech.com 25U Adjustable Depth 4 Post Open Frame Server Rack Cabinet In Stock £271.41
BP74 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £78.80
BP74 StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £30.39
BP74 StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £81.93
BP74 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £14.19
BP74 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £33.10
BP74 StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £26.81
BP74 StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £7.25
BP74 StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £11.79
BP74 StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £102.30
BP74 StarTech.com 25U 36in Server Rack Cabinet In Stock £552.38
BP74 StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters In Stock £490.71
Depth (mm): 51.9cm
Width (mm): 60.4cm
Price Range Ex VAT: 150 - 300
