StarTech.com PCIe 10Gb Fiber Card SFP+ NIC
Quicklinx: B147WS00 Mfr#: PEX10000SFP
21 in stock
£148.78 ex VAT
£178.53 inc VAT
Scale your network performance using the 10Gb SFP+ transceiver of your choice and connect your PCIe-enabled server to a 10 Gigabit fiber network. The PEX10000SFP 10 Gigabit Fiber Network Card is a cost-effective solution that delivers fast and reliable 10 Gbps network access at longer distances than copper-based networks. Using the SFP+ transceiver of your choice, you can connect your PCI Express-based server or workstation directly to your 10G fiber optic network.
With the rising strain on network resources due to large file transfers, multimedia content, and an increase in network users, more bandwidth is often required at various levels of your networking infrastructure. With up to 10 Gbps bandwidth, this fiber NIC lets you transfer more data at faster speeds, and is an ideal low-cost addition to your server or high-powered workstation.
The PEX10000SFP adapts to your network fiber connection and distance requirements to offer flexible configuration via an open SFP+ slot, and is compatible with most . With broad SFP+ compatibility this cost-effective fiber card lets you use your preferred SFP+ module, giving you more options to connect your computer directly to a fiber network at greater distances.
For improved operating efficiency, the PEX10000SFP features an energy-efficient Tehuti TN4010 chipset that offers significantly reduced power consumption versus most comparable cards, including the Intel 82599 chipset cards. Superior power efficiency also helps minimize heat generated by the card, in turn avoiding an increase in the operating temperature within your server case.
This versatile 10 Gbps network card offers 16K Jumbo Frame and 802.1q VLAN tagging support, as well as compatibility with VMWare ESXi 5.0/5.1, Microsoft Hyper-V virtualization software, and iSCSI support to combine LAN and SAN functions.
StarTech.com 10Gb SFP+ Network Card - PCIe 10 Gigabit Ethernet Fiber Network Card w/ Open SFP+ - PCIe x4 10Gb NIC SFP+ Card (PEX10000SFP) - network adapter - PCIe 2.0 x4
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x4
1.9 cm x 8.3 cm x 12 cm
43 g
Cabling Type
Ethernet 10GBase-LR, Ethernet 10GBase-SR, Ethernet 10GBase-LRM
10 GigE
Data Transfer Rate
10 Gbps
Jumbo frame size: 16000
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3aq
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, VMware ESXi 5.1, VMware ESXi 5.0, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, VMware ESXi 6.0, VMware ESXi 6.5, Microsoft Windows Hyper-V Server, Linux 2.6.24 - 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.10.3 - 10.14
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, MASFP10GBLR, MASFP10GBSR, SFP10GBBXDST, SFP10GBBXUST, SFP10GBERST, SFP10GBLRMST, SFP10GBLRST, SFP10GBSRST, SFP10GBZRST, SFP10GERST, SFP10GLRSST, SFP10GLRSTTA, SFP10GSRSST, SFP10GSRXST, TB31PCIEX16
Network adapter
PCI Express 2.0 x4
Wired
Cabling Type
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Status Indicators
Link/activity
Flow control, full duplex capability, Jumbo Frames support
1 - SFP+
Full-height bracket
FCC, RoHS
4.12 Watt
1.9 cm
8.3 cm
12 cm
43 g
70 °C
20 - 80% (non-condensing)
P/N: 455883B21ST, BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, ET10GSFP, EXSFP10GELRS, EXSFP10GESRS, J9150AST, J9151AST, J9152AST, JD092BST, JD094BST, MASFP10GBLR, MASFP10GBSR, SFP10GBBXDST, SFP10GBBXUST, SFP10GBERST, SFP10GBLRMST, SFP10GBLRST, SFP10GBSRST, SFP10GBZRST, SFP10GERST, SFP10GLRMST, SFP10GLRSST, SFP10GLRST, SFP10GLRSTTA, SFP10GSRSST, SFP10GSRST, SFP10GSRSTTA, SFP10GSRXST, TB31PCIEX16
B147 StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m In Stock £134.56
B147 StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £117.92
B147 StarTech.com PCI Express (PCIe) Gigabit Ethernet Multimode SC Fiber Network Card Adapter NIC - 550m In Stock £116.60
B147 StarTech.com PCIe 10Gb Fiber Card SFP+ NIC In Stock £148.78
B147 StarTech.com 10GBase-T SFP+ - 10G Copper In Stock £157.37
Price Range Ex VAT: 100 - 150
