The PCIX1PEX4 PCI-X to x4 PCI Express Adapter lets you install a low profile/half-height x4 PCI Express card into a full height PCI-X (3.3V, 64-bit) slot on a server or other high-end motherboard. With a physical x16 PCI Express female slot connector, the PCI-X to PCIe adapter card accepts all types of x16/x8/x4/x1 physical PCI Express cards (maximum speed of x4), allowing an older system to run the newest cards.
- StarTech.com PCI-X to x4 PCI Express Adapter Card - riser card
- Product Type
- Riser card
- 4 cm x 16.4 cm x 2 cm
- 41 g
- Power
- Power Provided
- 1-year warranty
- Product Type
- Riser card
- 4 cm
- 16.4 cm
- 2 cm
- 41 g
- Expansion Slots
- 1 (total) / 1 (free) x PCI Express x4
- Compatible Slots
- 1 x PCI-X
- FCC, RoHS
- Limited warranty - 1 year , Technical support - lifetime
- -40 °C
- 85 °C
