Add high speed Wireless-N connectivity to a desktop PC through PCI. The PCI300WN2X2 Wireless-N PCI Card adds high speed 802.11n network connectivity to almost any PCI-enabled desktop/workstation PC. Using a 2T2R (2 Transmitter/2 Receiver) design over the 2.4GHz frequency, the card supports 300Mbps data bandwidth over an 802.11n network, while providing optimal signal reception and range - the ideal WiFi card for Desktop PCs.
Backward compatible with 802.11b/g networks (11/54Mbps), this versatile WiFi N adapter offers a versatile wireless networking solution with support for standard and advanced security options such as WEP, WPA and WPA2, along with wireless Quality of Service (QoS) support and quick and easy setup through WPS.
This easy-to-install wireless PCI NIC also includes a low-profile adapter, which enables it to be installed as a half-height wireless PCI card that's suitable for Small Form Factor computers.
The PCI300WN2X2 PCI Wireless N adapter also includes free lifetime technical support, ensuring an excellent upgrade or first-time setup option.
- StarTech.com PCI 300 Mbps Wireless N Network Adapter 802.11n/g 2T2R - network adapter - PCI
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI
- Bus Voltage
- Universal (3.3 V & 5.0 V)
- 1.9 cm x 12.9 cm x 5.3 cm
- 50 g
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- Processor
- Ralink RT3062F
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Linux Kernel 2.6.32, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- 2-year warranty
- Network adapter
- Form Factor
- Plug-in card
- PCI
- Bus Voltage
- Connectivity Technology
- Wireless
- 300 Mbps
- Frequency Band
- 2.4 GHz
- Status Indicators
- Link/activity
- Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Ad-Hoc Mode, Wi-Fi Protected Setup (WPS), 2T2R MIMO technology
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- Gain Level
- 2 dBi
Processor / Memory
- Processor
- Ralink RT3062F
- Compatible Slots
- 1 x PCI
- Included Accessories
- Low-profile bracket
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 1.9 cm
- 12.9 cm
- 5.3 cm
- 50 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 10 - 90%
