The PEX4RISERF x4 to x4 PCI Express riser adapter card features a flexible cable that lets you install a PCI Express (x4/x1) card away from the system motherboard in a 1U rackmount or small form factor chassis, overcoming limitations created by having to mount expansion cards directly in a motherboard expansion slot.
- StarTech.com PCI Express x4 Left Slot Riser Adapter Card with Flexible Cable - riser card
- Product Type
- Riser card
- 10 cm x 17.9 cm x 1.5 cm
- 35 g
- Power
- Power Provided
- 2-year warranty
- Product Type
- Riser card
- 10 cm
- 17.9 cm
- 1.5 cm
- 35 g
- Expansion Slots
- 1 (total) / 1 (free) x PCI Express x4
- Compatible Slots
- 1 x PCI Express x4
- RoHS
- Limited warranty - 2 years , Technical support - lifetime
- 0 °C
- 60 °C
