StarTech.com PCI Express to Mini PCI Express Card Adapter
Quicklinx: 7WZ4WS00 Mfr#: PEX2MPEX
Type: Mini PCI card adapter
Compatibility: PC
Interface: PCI Express
£27.09 ex VAT
£32.50 inc VAT
Convert a Mini PCI Express Card into a Standard Desktop PCI Express Card. The PEX2MPEX PCI Express to Mini PCI Express Adapter Card enables Mini PCI Express cards (Mini Cards) to be used in a standard PCI Express card slot. These PCIe Mini Cards, which are typically designed for laptops or small form factor ITX computers, can be used normally inside more conventional desktop computers. The adapter card features a complete PCIe to Mini PCIe pass-through design that eliminates data transfer rate bottlenecks, while the included full and low profile installation brackets makes this adapter card compatible with most computer chassis.
StarTech.com PCI Express to Mini PCI Express Card Adapter - Mini PCI card adapter - PCIe
Interface Type
PCIe
2 cm x 7.4 cm x 6.8 cm
200 g
Microsoft Windows 7, Microsoft Windows Vista
Interface Type
PCIe
2 cm
7.4 cm
6.8 cm
200 g
Expansion Slots
1 x mini PCI
1 x USB - 4 pin USB Type B - internal
Compatible Slots
1 x PCI Express
FCC, RoHS
55 °C
5 - 95% (non-condensing)
7WZ4 StarTech.com ExpressCard to CardBus Laptop Adapter PC Card In Stock £45.16
7WZ4 StarTech.com PCI Express to PCI Adapter Card In Stock £29.99
7WZ4 StarTech.com PCI to PCI Express Adapter Card In Stock £23.49
Compatibility: PC
Price Range Ex VAT: 0 - 50
