The PEX8TO16R PCI Express x8 to x16 riser card allows for PCI Express (PCIe) cards up to x16 in size to be installed into x8 PCIe slots in a 1U rack mount chassis. A necessary accessory for almost any 1U chassis, this PCIe Riser card lets you expand system capabilities by adding IO ports or a dedicated graphics card.
- StarTech.com PCI Express Riser Card x8 to x16 Left Slot Adapter for 1U Servers - riser card
- Product Type
- Riser card
- 3.2 cm x 15.8 cm x 1.7 cm
- 25 g
- Power
- Power Provided
- 2-year warranty
- Product Type
- Riser card
- 3.2 cm
- 15.8 cm
- 1.7 cm
- 25 g
- Expansion Slots
- 1 (total) / 1 (free) x PCI Express x16
- Compatible Slots
- 1 x PCI Express x8
- RoHS
- Limited warranty - 2 years , Technical support - lifetime
- 0 °C
- 60 °C
