The PEX1RISERF x1 to x1 PCI Express riser card (with flexible cable) allows for installation of a x1 PCI Express (PCIe) card into a 1U rack mount or small form factor chassis that doesn't offer direct mounting to the motherboard.
- StarTech.com PCI Express Riser Card x1 Left Slot Adapter 1U with Flexible Cable - riser card
- Product Type
- Riser card
- 10 cm x 17.9 cm x 1.5 cm
- 30 g
- Power
- Power Provided
- 2-year warranty
- Product Type
- Riser card
- 10 cm
- 17.9 cm
- 1.5 cm
- 30 g
- Expansion Slots
- 1 (total) / 1 (free) x PCI Express x1
- Compatible Slots
- 1 x PCI Express x1
- RoHS
- Limited warranty - 2 years , Technical support - lifetime
- 0 °C
- 60 °C
