StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC
Quicklinx: 9MLQWS00 Mfr#: PEX1000SFP2
Wired / Wireless: Wired
Protocol: Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: Mac, PC
Type: Network adapter
12 in stock
£116.47 ex VAT
£139.76 inc VAT
The PEX1000SFP2 PCI Express Gigabit Fiber Network Card lets you connect a PCI Express-based computer directly to a fiber optic network using the Gigabit SFP of your choice.
This Gigabit fiber card adapts to your network fiber connection and distance requirements to offer flexible configuration via an open SFP slot. With broad SFP compatibility the fiber network card lets you use your preferred SFP, giving you more options to connect your computer directly to a fiber network.
With fiber connectivity, your network is not susceptible to electronic interference, often problematic with standard RJ45 copper networks, making this versatile fiber card ideal for secure network setups.
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - network adapter
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
1.8 cm x 12.8 cm x 11.8 cm
57 g
Cabling Type
Ethernet 1000Base-LX, Ethernet 1000Base-SX
GigE
Data Transfer Rate
1 Gbps
IEEE 802.3z, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.5 - 10.9, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only
Network adapter
PCI Express x1
Wired
Cabling Type
Gigabit Ethernet
Data Transfer Rate
1 Gbps
Remote Management Protocol
SNMP 1
Status Indicators
Link OK, link/activity
Flow control, full duplex capability, auto-uplink (auto MDI/MDI-X), Jumbo Frames support, 48KB packet buffer, PXE 2.1 support
1 - SFP (mini-GBIC)
Low-profile bracket
FCC, RoHS
3.2 Watt
Software Included
Drivers & Utilities
1.8 cm
12.8 cm
11.8 cm
57 g
45 °C
5 - 95% (non-condensing)
9MLQ StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £71.70
9MLQ StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) In Stock £42.04
9MLQ StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) In Stock £39.96
9MLQ StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC – 10 km (Mini-GBIC) In Stock £38.71
Compatibility: Mac
Compatibility: PC
Price Range Ex VAT: 100 - 150
