StarTech.com PCI Express 6 pin to 8 pin Power Adapter Cable
Quicklinx: 6BBMWS00 Mfr#: PCIEX68ADAP
Length: 15.5cm
More than 50 in stock
£6.22 ex VAT
£7.46 inc VAT
Connect a standard 6-pin PCI Express power connection on the Power Supply to 8-pin ATI and NVidia video cards. The PCIEX68ADAP PCI Express 6 pin to 8 pin power adapter cable lets you connect a standard 6-pin PCI Express power connection provided by the computer power supply to ATI and NVidia video cards that require an 8 pin power connection.
A cost-effective solution, the PCIe 6 pin to 8 pin power adapter eliminates the expense of upgrading a computer power supply for the sake of compatibility with a newer video card.
StarTech.com PCI Express 6 pin to 8 pin Power Adapter Cable - Power cable - 6 pin PCIe power (F) to 8 pin PCIe power (M) - 6.1 in - yellow - PCIEX68ADAP - power cable - 15.5 cm
Power cable
Length
15.5 cm
Connector
6 pin PCI Express power - female
Connector (Second End)
8 pin PCI Express power - male
Yellow
P/N: ATX2POWER430, ATX2POWER530
Power cable
Length
15.5 cm
Yellow
Connector
RoHS
StarTech.com 430 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, 530 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC
Length: 15.5cm
Price Range Ex VAT: 0 - 50
