StarTech.com PCI Express 2.0 SATA III Mini-SAS SFF-8087 RAID Controller Card - HyperDuo SSD Tiering
Quicklinx: 8NV5WS00 Mfr#: PEXSAT34SFF
  • Windows 8 (32/64 bits)
Add Internal SATA III (6Gbps) support to a computer through a single Mini SAS port. The PEXSAT34SFF PCI Express 2.0 SATA Controller Card enables 4 AHCI SATA III connections to be added to a computer through a single internal Mini-SAS connector.
The Mini-SAS connector with Port Multiplier support allows for multiple SATA drives (up to 7) to be connected using a single cable.
Featuring HyperDuo technology, the SATA card offers SSD auto-tiering which lets you balance the performance advantages of SSD storage with the cost-effectiveness and large capacity of standard hard drives. By combining SSD and HDD drives into a single volume (up to 3 SSD + 1 HDD), HyperDuo discreetly works in the background to identify and move frequently accessed files to the faster SSD drive(s) for improved data throughput - up to 80% of SSD performance!
Compliant with SATA revision 3.0, this PCI Express SATA RAID card delivers up to 6Gbps of data bandwidth; ideal for high performance hard drives and solid state drives (SSD). Plus, the controller card offers an effective hardware RAID solution, with native RAID (0, 1, 1+0) support.
StarTech.com PCI Express SATA III Mini-SAS RAID Controller Card w/ HyperDuo - storage controller (RAID) - SATA 6Gb/s / SAS 6Gb/s - PCIe 2.0 x2
Storage controller (RAID) - plug-in card - low profile
Bus Type
PCIe 2.0 x2
Data Transfer Rate
6 Gbit/s
Supported Devices
Disk array (RAID)
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10, JBOD
Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
12 cm x 7 cm x 2 cm
40 g
Host Bus
PCIe 2.0 x2
Storage Controller
Data Transfer Rate
6 Gbit/s
Supported Devices
Disk array (RAID)
Channel Qty
4
RAID Level
Marvell 88SE9230
1 x SATA 6Gb/s / SAS 6Gb/s - 36 pin 4i Mini MultiLane (internal)
Compatible Slots
1 x PCI Express 2.0 x2
Low-profile bracket
FCC, RoHS
12 cm
7 cm
2 cm
40 g
5 °C
50 °C
20 - 80% (non-condensing)
8NV5 StarTech.com 50cm Serial Attached SCSI SAS Cable - SFF-8087 to 4x Latching SATA In Stock £35.54
8NV5 StarTech.com 1m Serial Attached SCSI SAS Cable - SFF-8087 to 4x Latching SATA In Stock £31.37
