The PLUS-LR-ST is a Palo Alto Networks PLUS-LR compatible fiber transceiver module that has been designed, programmed and tested to work with Palo Alto Networks brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-LR compliant networks, with a maximum distance of up to 0 km (6.2 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Palo Alto Networks PLUS-LR Compatible SFP+ Module, 10GBASE-LR, 10GbE Single Mode (SMF) Fiber SMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 10km, 1310nm, DDM - Lifetime Warranty (PLUS-LR-ST) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-LR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- Palo Alto Networks PLUS-LR
- 5.84 cm x 1.39 cm x 1.37 cm
- 21 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-LR
- 10GbE
- 10 Gbps
- 1310 nm
- 10 km
- Full duplex mode, Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 10GBase-LR - LC single-mode female x 2
- MTBF
- 1,386,624,697 hours
- FCC, MSA
- 1.3 Watt
- 5.84 cm
- 1.39 cm
- 1.37 cm
- 21 g
- Shipping Width
- 9 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.1 cm
- Shipping Weight
- 50 g
- Limited warranty - lifetime
