StarTech.com Outdoor 300 Mbps 2T2R Wireless-N Access Point - 5GHz 802.11a/n PoE-Powered WiFi AP
Quicklinx: 9KRQWS00 Mfr#: R300WN22OP5G
Type: Radio access point
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11a, IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
Hurry, only 1 left in stock!
£51.22 ex VAT
£61.46 inc VAT
Create or extend the range of a Wireless-N (300Mbps) WiFi network to an outdoor location. The R300WN22OP5G Outdoor Wireless Access Point lets you create or extend the range of a 5GHz Wireless-N (300Mbps) network to an outdoor location, letting your wireless devices connect to your network with enhanced reliability and speed, with less network congestion.
By isolating your wireless network to a 5GHz frequency, your dual-band smartphone, tablet or laptop operates with less interference from other devices on common 2.4GHz networks. For ideal wireless coverage across large outdoor areas, the access point integrates into your existing Wireless A/N or wired network to broadcast a WiFi SSID via a high-power 600mW internal 14dBi 2T2R directional antenna.
This PoE-powered access point includes a passive Power-over-Ethernet injector, so it can be conveniently installed in locations where a typical power outlet is unavailable. Plus, PoE-pass-through via dual RJ-45 LAN ports lets you connect a PoE-capable device at the access points remote location. For versatile outdoor installation, the access point features a weather-resistant housing and is pole and wall-mountable for easier placement.
Supporting wireless data rates up to 300Mbps, the high-performance outdoor AP is compatible with 802.11a/n devices, offers support for WEP, WPA, and WPA2 authentication, incorporates switchable WISP or Bridged operation modes and is configurable through an easy-to-use web-based utility.
StarTech.com Outdoor 300 Mbps 2T2R Wireless-N Access Point - 5GHz WiFi AP - radio access point
Radio access point
External - outdoor
Atheros AR9344
Frequency Band
5 GHz
PoE injector
Power Over Ethernet (PoE) Supported
PoE
9.2 cm x 29.1 cm x 5.9 cm
310 g
Radio access point
Ruggedized Design
Outdoor
9.2 cm
29.1 cm
5.9 cm
310 g
Enclosure Colour
White
Processor / Memory / Storage
Processors Installed
Atheros AR9344
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
64 QAM, BPSK, QPSK, 16 QAM, OFDM
Network / Transport Protocol
CSMA/CA
Frequency Band
5 GHz
Max Range Open Space
10 km
Status Indicators
Power, link/activity
2T2R MIMO technology
Encryption Algorithm
TKIP, WPA, WEP
IEEE 802.3, IEEE 802.3u, IEEE 802.11a, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
1
Directivity
Directional
Gain Level
14 dBi
2 x - RJ-45
PoE injector
RoHS
PoE
External power adapter
-20 °C
70 °C
0 - 90%
9KRQ StarTech.com 25 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £7.22
9KRQ StarTech.com Outdoor 300 Mbps 2T2R Wireless-N Access Point - 5GHz 802.11a/n PoE-Powered WiFi AP In Stock £51.22
Speed: 300Mbps
Protocol: IEEE 802.11n
Compatibility: PC
Price Range Ex VAT: 50 - 100
