Product
StarTech.com Outdoor 150 Mbps 1T1R Wireless-N Access Point - 2.4GHz 802.11b/g/n PoE-Powered WiFi AP
Quicklinx: 949TWS00 Mfr#: AP150WN1X1OG
  • IEEE 802.11n
Create a long-range, high-performance Wireless-N network from a wired connection - PoE powered. The AP150WN1X1OG Outdoor Wireless Access Point lets you create a long-range 150Mbps Wireless-N network outdoors, through a wired network connection, providing wireless connectivity for mobile devices such as Smartphones, tablets, and laptops.
This PoE-powered access point comes complete with a PoE Injector, so it can be conveniently installed in locations where a typical power outlet is unavailable. For versatile outdoor installation, the weather-resistant housing is pole and wall-mountable.
The AP offers an internal 1T1R 12dBi directional antenna with adjustable output strength to suit your required coverage area. The access point also integrates an optional RP-SMA connection so you can attach an external antenna and a secondary LAN port to connect to an additional wired network device, if needed.
Supporting wireless data rates up to 150Mbps on the 2.4GHz frequency, the high-performance wireless AP is compatible with 802.11b/g/n devices and offers support for WEP, WPA, and WPA2 authentication. The wireless access point incorporates an easy-to-use web-based utility to provide several customization options such as multiple SSIDs, remote firmware upgrades and Wireless Distribution System (WDS) mode support which can mesh multiple APs together to cover larger areas.
StarTech.com Outdoor 150 Mbps 1T1R Wireless-N Access Point - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
AC 120/230 V
29.1 cm x 5.9 cm x 9.2 cm
340 g
Radio access point
29.1 cm
5.9 cm
9.2 cm
340 g
Enclosure Colour
White
External
Wireless
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
Wireless Distribution System (WDS) support, 1T1R MIMO technology
Encryption Algorithm
AES, TKIP, WPA, WPA2, WEP
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
1
Directivity
Directional
Gain Level
12 dBi
1 x 100Base-TX - RJ-45 , 1 x aerial - RP-SMA
FCC, RoHS
External power adapter
AC 120/230 V
70 °C
10 - 90%
949T StarTech.com 25 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £7.36
