StarTech.com OTG USB Card Reader Dongle
Quicklinx: C196WS00 Mfr#: FCREADUOTGDB
Enjoy fast, easy access to memory cards (SD, Micro SD and compact flash cards) using your OTG-enabled smartphone or tablet. Now you can quickly access photos, video and data from a MicroSD card, SD card or USB-attached storage device using your Micro USB On-The-Go (OTG) enabled tablet or smartphone. This compact, dongle-style memory card reader is compatible with any OTG-enabled mobile device such as the Samsung Galaxy, Sony Xperia, HTC mobile devices and other Micro USB-equipped tablets and smartphones.
This versatile memory card reader gives you quick access to data on SD or MicroSD cards or USB attached storage devices, expanding the capabilities of your smartphone or tablet. The card reader offers flexible use, letting you connect easily to your tablet or smartphone, no matter where the Micro USB connector is located on the device.
The OTG card reader makes it easier to share high-quality images and video. You can shoot video or photos with your high-end digital camera; connect the memory card in your smartphone and instantly view and upload your images to Facebook, Twitter or Instagram.
This lightweight, pocket-sized memory card reader is the ideal accessory for your smartphone, tablet or laptop. It simply tucks it into a pocket in your laptop or camera bag for easy, portable use.
The memory card reader features a fully functional USB 2.0 port that lets you connect USB devices such as a USB flash drive, mouse or keyboard to your OTG-enabled mobile device. The adapter dongle also features a USB DC power connection which enables the adapter and connected smartphone or tablet to access data on a USB attached storage device, such as a USB 2.5" HDD enclosure, to add data storage.
StarTech.com OTG USB Card Reader Dongle for Mobile Devices - SD & Micro SD - card reader - USB 2.0
Card reader - external
Supported Memory Cards
SD Memory Card, microSD, SDHC Memory Card, microSDHC, SDXC Memory Card, microSDXC
Host Interface
USB 2.0
Built-in USB hub, power indicator
Host Interface
USB 2.0
5.6 cm
18 cm
0.7 cm
13 g
Memory Card
(max)
Additional Ports
1 x USB 2.0 , 1 x Micro-USB 2.0
Required Ports
1 x 5 pin Micro-USB Type B
Plug and Play, FCC, RoHS
