Cost-effective way of converting a straight through cable into a null modem cable. The NM25MM Null Modem Adapter features two DB25 male connectors enabling you to convert a straight through cable into a null modem cable for connecting two serial devices.
- StarTech.com Null Modem Adapter DB25M to DB25M - null modem adapter - DB-25 to DB-25
- Null modem adapter
- Connector
- 25 pin D-Sub (DB-25) - male
- Connector (Second End)
- Limited lifetime warranty
- Connector
