No-Stud TV Wall Mount - Slim Design with Tilt - For 37" to 80" Displays
This No-Stud TV Wall Mount enables you to easily and securely mount your display from 37" up to 80" to walls without the need to align the bracket with wall studs. Its steel frame supports displays up to 110lb / 50kg in weight and provides the ability to tilt your display to ensure your application and the ideal viewing angle are aligned.
Easy and Flexible Installation
The studless design of this Universal TV Wall Mount makes it easy for you to mount your TV to a drywall or plaster wall in any boardroom, office, or classroom setup. Simply choose the best mounting location and secure the mounting bracket into the wall (with included nails); no need to drill or look for wall studs. The included Automatic Spring Lock lets you conveniently mount and secure your TV in place.
Low Profile Slim Design
This Low Profile TV Wall Mount is perfect for applications like digital signage, where space and aesthetics are important. With a 1.2" profile from the wall, this Wall Mount TV Hanger provides a professional and clean look.
Tilt your Display
The Hanging TV Wall Mount lets you angle your TV towards your audience. The included wall-mounted spacers give you a choice to change the tilting angle (0°/ -5°) for a comfortable viewing experience.
The FPWHANGER is backed by a StarTech.com 5-year warranty and free lifetime technical support.
The studless design of this Universal TV Wall Mount makes it easy for you to mount your TV to a drywall or plaster wall in any boardroom, office, or classroom setup. Simply choose the best mounting location and secure the mounting bracket into the wall (with included nails); no need to drill or look for wall studs. The included Automatic Spring Lock lets you conveniently mount and secure your TV in place. -
- StarTech.com No-Stud TV Wall Mount, Low Profile Heavy Duty VESA TV Wall Mount for up to 80 inch Display (110lb/50kg), Universal Television Wall Mount, Studless Tilting Flat Screen Mount - No Drill TV Mount mounting kit - for TV - black
- Product Type
- Mounting kit - wall-mountable
- 7 cm x 13.3 cm x 3.1 cm
- Tilt
- -5° to 0°
- 2.4 kg
- Recommended Use
- TV
- Recommended Display Size
- 37"-80"
- VESA Mounting Interface
- 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 200 mm, 300 x 300 mm
- Max Load Weight
- 50 kg
- Material
- Steel
- Black
- Package Content
- 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 4 x concrete anchors, 4 x M8x50 screws, 4 x mounting screws
- 5-year warranty
- 7 cm
- 13.3 cm
- 3.1 cm
- 2.4 kg
- Material
- Steel
- Black
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- TV
- Placing / Mounting
- Wall-mountable
- 37"-80"
- Tilt
- -5° to 0°
- Max Load Weight
- 50 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 76.9 cm x 20 cm x 4.5 cm / 2.6 kg
- Limited warranty - 5 years
StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay | In Stock | £2.96 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.55 |
StarTech.com 10m CL2 Active HDMI Cable - 4K | In Stock | £78.49 |
